14 years agoWriting to SRAM
Hi everyone, Does anyone have a tutorial that shows me how to write to Memory using SOPC? Thanks
14 years ago --- Quote Start --- Well, I am using a State Machine not NIOS. This is why I want to switch to NIOS maybe I will be get a better luck. I am not implementing any handshake protocol ! I am just using an 115200 8N1 with no applied protocol! Is this bad? --- Quote End --- That should work fine. --- Quote Start --- Here is my code (its a code I got from the net :oops: ) --- Quote End --- Its very difficult to read code and see bugs (other than the obvious). You should really create a simulation and see if the code responds correctly to serial characters on its input and generates them on its output. Cheers, Dave
