14 years agoWriting to SRAM
Hi everyone, Does anyone have a tutorial that shows me how to write to Memory using SOPC? Thanks
14 years ago --- Quote Start --- Can you confirm that its the PC that is the problem? Perhaps it is the FPGA. If the RS232 interface does not implement the CTS/RTS handshake wires, then you could be overrunning your buffers in the FPGA. What is processing your RS232 data; is it a state machine, or a NIOS II processor? The tutorial I linked to shows how to use the JTAG interface to implement access to the board. Using master_write_memory and master_read_memory within system console, you can get about 600kbps (73kB/s) transfer rate. Cheers, Dave --- Quote End --- Hi Dave, Thanks again for your help. Well, I am using a State Machine not NIOS. This is why I want to switch to NIOS maybe I will be get a better luck. I am not implementing any handshake protocol ! I am just using an 115200 8N1 with no applied protocol! Is this bad? Here is my code (its a code I got from the net :oops: ) { module async_receiver(clk, RxD, RxD_data_ready, RxD_data, RxD_endofpacket, RxD_idle); input clk, RxD; output RxD_data_ready; // onc clock pulse when RxD_data is valid output [7:0] RxD_data; parameter ClkFrequency = 100000000; // 50MHz //parameter ClkFrequency = 27000000; // 27MHz parameter Baud = 115200; //parameter Baud = 9600; // We also detect if a gap occurs in the received stream of characters // That can be useful if multiple characters are sent in burst // so that multiple characters can be treated as a "packet" output RxD_endofpacket; // one clock pulse, when no more data is received (RxD_idle is going high) output RxD_idle; // no data is being received // Baud generator (we use 8 times oversampling) parameter Baud8 = Baud*8; parameter Baud8GeneratorAccWidth = 16; parameter Baud8GeneratorInc = ((Baud8<<(Baud8GeneratorAccWidth-7))+(ClkFrequency>>8))/(ClkFrequency>>7); reg [Baud8GeneratorAccWidth:0] Baud8GeneratorAcc; always @(posedge clk) Baud8GeneratorAcc <= Baud8GeneratorAcc[Baud8GeneratorAccWidth-1:0] + Baud8GeneratorInc; wire Baud8Tick = Baud8GeneratorAcc[Baud8GeneratorAccWidth]; //////////////////////////// reg [1:0] RxD_sync_inv; always @(posedge clk) if(Baud8Tick) RxD_sync_inv <= {RxD_sync_inv[0], ~RxD}; // we invert RxD, so that the idle becomes "0", to prevent a phantom character to be received at startup reg [1:0] RxD_cnt_inv; reg RxD_bit_inv; always @(posedge clk) if(Baud8Tick) begin if( RxD_sync_inv[1] && RxD_cnt_inv!=2'b11) RxD_cnt_inv <= RxD_cnt_inv + 1; else if(~RxD_sync_inv[1] && RxD_cnt_inv!=2'b00) RxD_cnt_inv <= RxD_cnt_inv - 1; if(RxD_cnt_inv==2'b00) RxD_bit_inv <= 0; else if(RxD_cnt_inv==2'b11) RxD_bit_inv <= 1; end reg [3:0] state; reg [3:0] bit_spacing; // "next_bit" controls when the data sampling occurs // depending on how noisy the RxD is, different values might work better // with a clean connection, values from 8 to 11 work wire next_bit = (bit_spacing==10); always @(posedge clk) if(state==0) bit_spacing <= 0; else if(Baud8Tick) bit_spacing <= {bit_spacing[2:0] + 1} | {bit_spacing[3], 3'b000}; always @(posedge clk) if(Baud8Tick) case(state) 4'b0000: if(RxD_bit_inv) state <= 4'b1000; // start bit found? 4'b1000: if(next_bit) state <= 4'b1001; // bit 0 4'b1001: if(next_bit) state <= 4'b1010; // bit 1 4'b1010: if(next_bit) state <= 4'b1011; // bit 2 4'b1011: if(next_bit) state <= 4'b1100; // bit 3 4'b1100: if(next_bit) state <= 4'b1101; // bit 4 4'b1101: if(next_bit) state <= 4'b1110; // bit 5 4'b1110: if(next_bit) state <= 4'b1111; // bit 6 4'b1111: if(next_bit) state <= 4'b0001; // bit 7 4'b0001: if(next_bit) state <= 4'b0000; // stop bit default: state <= 4'b0000; endcase reg [7:0] RxD_data; always @(posedge clk) if(Baud8Tick && next_bit && state[3]) RxD_data <= {~RxD_bit_inv, RxD_data[7:1]}; reg RxD_data_ready, RxD_data_error; always @(posedge clk) begin RxD_data_ready <= (Baud8Tick && next_bit && state==4'b0001 && ~RxD_bit_inv); // ready only if the stop bit is received RxD_data_error <= (Baud8Tick && next_bit && state==4'b0001 && RxD_bit_inv); // error if the stop bit is not received end reg [4:0] gap_count; always @(posedge clk) if (state!=0) gap_count<=0; else if(Baud8Tick & ~gap_count[4]) gap_count <= gap_count + 1; assign RxD_idle = gap_count[4]; reg RxD_endofpacket; always @(posedge clk) RxD_endofpacket <= Baud8Tick & (gap_count==15); endmodule } Pleasae let me know
