14 years agoWriting to SRAM
Hi everyone, Does anyone have a tutorial that shows me how to write to Memory using SOPC? Thanks
14 years ago --- Quote Start --- I established an RS232 commuincation between PC and the Board and It was great. However, the RS232 program such as HyperTerminal, PuTTY, and Tera Time are not realiable! Sometimes I can transfer a whole file o.k and other times I can't ?!!! --- Quote End --- Can you confirm that its the PC that is the problem? Perhaps it is the FPGA. If the RS232 interface does not implement the CTS/RTS handshake wires, then you could be overrunning your buffers in the FPGA. What is processing your RS232 data; is it a state machine, or a NIOS II processor? The tutorial I linked to shows how to use the JTAG interface to implement access to the board. Using master_write_memory and master_read_memory within system console, you can get about 600kbps (73kB/s) transfer rate. Cheers, Dave
