14 years agowrite master intermittent issues
I have an SOPC system and a write master. I use the write master to write in a 128 bit word into onchip memory every 1 second (the same address). Some of the time, it works fine but when I make a ver...
14 years ago --- Quote Start --- i'm having troublee identifiying the problem. --- Quote End --- 1) Use SignalTap to probe the Avalon bus when you have the problem. 2) Simulate the system using Modelsim and recreate the stimulus that is causing the hardware problem. 3) Debug, and repeat from (1). Cheers, Dave
