11 years agowhy DMA not done?
I have problem to use DMA to transfer data from memory to memory, also memory to peripherals. Each time I start a DMA, it is not done, the DONE bit will not be set, and my problem keep in busy waiting the bit. Here is my program, I think there is no problem. Anyone can help?
#include<stdio.h>
#include<stdlib.h>
#include<stddef.h>
#include<string.h>
#include<system.h>
#include<io.h>
#include<alt_types.h>
#include"sys/alt_dma.h"
#include"sys/alt_cache.h"
#include"sys/alt_alarm.h"
#include"alt_types.h"
static volatile int txrx_done = 0;
//callback function when DMA transfer done
static void txrxDone(void * handle, void * data)
txrx_done = 1;
void initMEM(void* base_addr,int len)
int i;
for (i=0;i<len;i++)
IOWR_16DIRECT(base_addr,i,i);
static alt_16 txbuff;
static alt_16 rxbuff;
int main()
int i;
printf("testing sdram to sdram : DMA operation\n");
initMEM((void*)txbuff, 0x10);
memset(rxbuff, 0, sizeof(rxbuff));
printf("content of txbuff:before DMA operation\n");
for (i=0;i<0x10;i++)
printf("%d: %x\n",i,IORD_16DIRECT(txbuff,i));
printf("content of rxbuff:before DMA operation\n");
printf("%d: %x\n",i,IORD_16DIRECT(rxbuff,i));
int rc; //request
alt_dma_txchan txchan;
alt_dma_rxchan rxchan;
void* tx_data = (void*)alt_remap_uncached(txbuff, sizeof(txbuff)); /* pointer to data to send */
void* rx_data = (void*)alt_remap_uncached(rxbuff, sizeof(rxbuff)); /* pointer to rx buffer */
/* Create the transmit channel */
if ((txchan = alt_dma_txchan_open("/dev/dma_3")) == NULL)
printf ("Failed to open transmit channel\n");
exit(1);
/* Create the receive channel */
if ((rxchan = alt_dma_rxchan_open("/dev/dma_3")) == NULL)
printf ("Failed to open receive channel\n");
exit(1);
/* Post the transmit request */
if ((rc = alt_dma_txchan_send (txchan,
tx_data,
0x20,
NULL,
NULL)) < 0)
printf ("Failed to post transmit request, reason = %i\n", rc);
exit (1);
/* Post the receive request */
if ((rc = alt_dma_rxchan_prepare (rxchan,
rx_data,
0x20,
txrxDone,
NULL)) < 0)
printf ("Failed to post read request, reason = %i\n", rc);
exit (1);
/* wait for transfer to complete */
while (!txrx_done);
printf ("Transfer successful!\n");
printf("content of rxbuff:after DMA operation\n");
printf("content of txbuff:after DMA operation\n");
alt_dma_rxchan_close (rxchan);
alt_dma_txchan_close (txchan);
return 0;
Also I attached the qsys file.1 Reply
Have you tried simulation?
