19 years agowhy 3-wire spi have 4-prot ??
Dear ALL I want to use the spi in sopc builder . but I find it have 4 paort . i can connect it to my extern device . I want to know how to do it . thanks!
19 years ago --- Quote Start --- originally posted by badomen@Nov 10 2006, 11:47 PM you should get four signals at the top level:
sclk (serial clock)
mosi (master out slave in) --> so if you use a spi master in sopc builder this is your serial output
miso (master in slave out) --> so if you use a spi master in sopc builder this is your serial input
ss/ss_n (slave select)
so if the component you are trying to talk to can only do reads for example you don't need to use the mosi signal (your component can't do anything with the data).
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19370)
--- quote end ---
--- Quote End --- sopc builder shows only 3 pins either for master or slave how can we include the 4th pin as in the spi protocol. thanks in advance.
