17 years ago
Who have the code of Scatter-Gather DMA?
I meet a lot of problems of Scatter-Gather DMA,i do not have the example of Scatter-Gather DMA.it is very hard to make it.some one who have the code of Scatter-Gather DMA please upload it.
thanks in advance
    Here you go: http://www.altera.com/support/examples/nios2/exm-scatter-gather-dma.html
    There will be a new "Modular SGDMA" that will be posted up on the Nios II design examples page shortly. It doesn't use descriptor fetching and as a result is much easier to use in my opinion. If you want to take a look at it send me a message with your email address and I'll forward it to you. This is the Modular SGDMA feature list that isn't present in the SGDMA today:
    • Up to 4GB transfer lengths
    • ST-->MM early termination (packet length limiting)
    • Interrupts per descriptor
    • MM-->ST error signal
    • Burst boundary re-alignment
    • Park mode built into the descriptor (makes frame buffering easy)
    • Descriptor sequence numbering (tag the descriptors then readback from the SGDMA to find out which descriptor the read and write masters are working on)
    • Descriptor programmable burst
    • Descriptor stride (address increment for fixed/interleaved data)
    • Data widths up to 1024 bits
    • Independent reads and writes (i.e. descriptors are dual buffered so the write master does not block the read master from starting up again)
    • Burst lengths up to 1024 beats
    • User selectable data/descriptor FIFO depths
    -JCJB
    thank you for your suggestion,but i want to learn the descriptor to control the SGDMA,so i wish you give me an example of the SGDAM.
    my mailbox address is:
    [email protected]
    thank you very much
    It was moved to the alterawiki. If you search for "modular SGDMA" on the wiki it should bring you to the correct page.
