21 years agowho can help me about I2C
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif I 'm test the EEPROM of I2C interface,and meet a problem. I use the "opencores I2C master " module. step 1, ...
21 years agoFor the IP core ,you could download the NIOS2 linux1.3 , then set up the nios2linux 1.3 and you could see the IP core in SOPC builder!
List is my soyurce code for test IIC , help me! I2C_prescale=ALT_CPU_FREQ/(5*100000)-1;//ALT_CPU_FREQ is in "system.h" IOWR(I2C_BASE,I2C_PRERlo,I2C_prescale); IOWR(I2C_BASE,I2C_PRERhi,I2C_prescale>>8); // high 8 bits PRERhi=IORD(I2C_BASE,I2C_PRERhi);//read again printf(" again PRERhi=%d\n",PRERhi); PRERlo=IORD(I2C_BASE,I2C_PRERlo); printf("again PRERlo=%d\n",PRERlo); //enable I2C CTR=IORD(I2C_BASE,I2C_CTR); printf("CTR=%2x\n",CTR); IOWR(I2C_BASE,I2C_CTR,0x80); CTR=IORD(I2C_BASE,I2C_CTR); printf("CTR=%2x\n",CTR); for(j=1;j<=8;j++) { printf("IIC test=%2x\n",j); //slect device CSR=IORD(I2C_BASE,I2C_CSR); printf("1 CSR=%2x\n",CSR); IOWR(I2C_BASE,I2C_DATA,E2PROM_ADDR); //ob1010000 0 ,prepare the data first IOWR(I2C_BASE,I2C_CSR,0x91); //STA,WR,IACK ,start transferring //select memory while((CSR=IORD(I2C_BASE,I2C_CSR))&0x02) printf("2 busy CSR=%2x\n",CSR) ; //tip=1 :when transferring data while((CSR=IORD(I2C_BASE,I2C_CSR))&0x80) printf("3 no ack CSR=%2x\n",CSR) ; //rxack=0: Acknowledge received IOWR(I2C_BASE,I2C_DATA,eeprom_a+j); IOWR(I2C_BASE,I2C_CSR,0x11); //WR,IACK CSR=IORD(I2C_BASE,I2C_CSR); printf("4 CSR=%2x\n",CSR); //write data and terminate while((CSR=IORD(I2C_BASE,I2C_CSR))&0x02) printf("5 busy CSR=%2x\n",CSR) ; //tip=1 while((CSR=IORD(I2C_BASE,I2C_CSR))&0x80) printf("6 no ack CSR=%2x\n",CSR) ; //rxack=0 //j=1; IOWR(I2C_BASE,I2C_DATA,eeprom_d+j); IOWR(I2C_BASE,I2C_CSR,0x51); //STO,WR,IACK while((CSR=IORD(I2C_BASE,I2C_CSR))&0x02) //tip=1 printf("7 busy CSR=%2x\n",CSR); while((CSR=IORD(I2C_BASE,I2C_CSR))&0x80) //rxack=0 printf("8 no ack CSR=%2x\n",CSR); i = 0; while (i<200000) i++; i = 0; while (i<200000) i++; CSR=IORD(I2C_BASE,I2C_CSR); printf("9 CSR=%2x\n",CSR); /////////////////////////////////////////////////////////////// //read back ///////////////////////////////////// //slect device COMMAND 1 IOWR(I2C_BASE,I2C_DATA,E2PROM_ADDR); IOWR(I2C_BASE,I2C_CSR,0x91); //STA,WR,IACK //select memory while((CSR=IORD(I2C_BASE,I2C_CSR))&0x02); //tip=1 printf("10 CSR=%2x\n",CSR); //rxack=0 while((CSR=IORD(I2C_BASE,I2C_CSR))&0x80); //rxack=0 IOWR(I2C_BASE,I2C_DATA,eeprom_a+j-1); IOWR(I2C_BASE,I2C_CSR,0x11); //WR,IACK //select device and READ COMMAND 2 while((CSR=IORD(I2C_BASE,I2C_CSR))&0x02); //tip=1 while((CSR=IORD(I2C_BASE,I2C_CSR))&0x80); //rxack=0 IOWR(I2C_BASE,I2C_DATA,E2PROM_ADDR+1); //device address and READ IOWR(I2C_BASE,I2C_CSR,0x91); //re-STA,WR,IACK //read data and terminate while((CSR=IORD(I2C_BASE,I2C_CSR))&0x02) //tip=1 { printf(" test1 CSR=%2x\n",CSR); } CSR=IORD(I2C_BASE,I2C_CSR); printf(" test2 CSR=%2x\n",CSR); IOWR(I2C_BASE,I2C_CSR,0x21); //RD,ACK,IACK (0b0010 0001) while (i<50000) i++; Readdata_I2C_B=0x00; Readdata_I2C_B=IORD(I2C_BASE,I2C_DATA); printf(" Readdata_I2C_B=%2x\n",Readdata_I2C_B); //rxack=0 while((CSR=IORD(I2C_BASE,I2C_CSR))&0x02); //tip=1 { printf(" test3 CSR=%2x\n",CSR); //rxack=0 } //2005,07,20 shield //while((CSR=IORD(I2C_BASE,I2C_CSR))&0x80); //rxack=0 maybe not need the lopp //2005,07,20 IOWR(I2C_BASE,I2C_CSR,0x69); //STO,RD,NACK,IACK (0b01101001) while((CSR=IORD(I2C_BASE,I2C_CSR))&0x02); //tip=1 // while((CSR=(I2C_BASE,I2C_CSR))&0x80) printf(" 11 CSR=%2x\n",CSR); //rxack=0 Readdata_I2C=0x00; Readdata_I2C=IORD(I2C_BASE,I2C_DATA); if(Readdata_I2C==(eeprom_d+j)) printf("write data= %2x Readdata_I2C=%2x\n OK\n!",eeprom_d+j,Readdata_I2C); else printf("write data= %2x Readdata_I2C=%2x\n ERROR!\n",eeprom_d+j,Readdata_I2C); i = 0; while (i<200000) i++; i = 0; while (i<200000) i++; } // Have been tested OK ! // continuous read 8 bytes data by "sequential read " command printf(" IIC continously read test\n"); //rxack=0 //slect device COMMAND 1 IOWR(I2C_BASE,I2C_DATA,E2PROM_ADDR); IOWR(I2C_BASE,I2C_CSR,0x91); //STA,WR,IACK //select memory while((CSR=IORD(I2C_BASE,I2C_CSR))&0x02); //tip=1 printf("c1 CSR=%2x\n",CSR); //rxack=0 while((CSR=IORD(I2C_BASE,I2C_CSR))&0x80); //rxack=0 IOWR(I2C_BASE,I2C_DATA,eeprom_a); // from first address IOWR(I2C_BASE,I2C_CSR,0x11); //WR,IACK //select device and READ COMMAND 2 while((CSR=IORD(I2C_BASE,I2C_CSR))&0x02); //tip=1 while((CSR=IORD(I2C_BASE,I2C_CSR))&0x80); //rxack=0 IOWR(I2C_BASE,I2C_DATA,E2PROM_ADDR+1); //device address and READ IOWR(I2C_BASE,I2C_CSR,0x91); //re-STA,WR,IACK //read data and terminate // prepare to get date // need judge ACK while((CSR=IORD(I2C_BASE,I2C_CSR))&0x02); //tip=1 while((CSR=IORD(I2C_BASE,I2C_CSR))&0x80); //rxack=0 for(j=1;j<=6;j++) // when I change the loop number, the last byte is always right { CSR=IORD(I2C_BASE,I2C_CSR); printf(" C2 CSR=%2x\n",CSR); while(((CSR=IORD(I2C_BASE,I2C_CSR))&0x02)== 0x20) //tip=1 { printf(" C3 CSR=%2x\n",CSR); } CSR=IORD(I2C_BASE,I2C_CSR); printf(" C4 CSR=%2x\n",CSR); IOWR(I2C_BASE,I2C_CSR,0x21); //ACK,IACK (0b0010 0001) Readdata_I2C_B=0x00; Readdata_I2C_B=IORD(I2C_BASE,I2C_DATA); printf(" data= %2x Readdata_I2C_B=%2x\n OK!",j,Readdata_I2C_B); } // read 6 bytes ,all is error while((CSR=IORD(I2C_BASE,I2C_CSR))&0x02) //tip=1 { printf(" C5 CSR=%2x\n",CSR); //rxack=0 } IOWR(I2C_BASE,I2C_CSR,0x69); // STO,RD,NACK,IACK (0b01101001) while((CSR=IORD(I2C_BASE,I2C_CSR))&0x02); //tip=1 printf(" C6 CSR=%2x\n",CSR); //rxack=0 Readdata_I2C=0x00; Readdata_I2C=IORD(I2C_BASE,I2C_DATA); // the last byte is OK! printf("data = 8 Readdata_I2C=%2x\n OK!",Readdata_I2C);
