15 years agowhere to find the factory_default.sof for cycloneIII_3c120_dev
Hi, All Could anyone help me to find this pof file: cycloneIII_3c120_dev_factory_recovery.pof I want to make the c3_3c120_dev_kit to the factory default setting based on the P25-36208-03_c...
14 years agowhat files do you have in the factory recovery folder? Did you download the kit support files from the link I gave? If you have the 9.0/9.1 versions, the .pof file should directly be there.
If you have a newer version, then you'll have a script that will reprogram the flash. The procedure is described in the user guide, chapter "Restoring the Flash Device with the Factory Settings"
