16 years agoWhere can i get "advanced_boot_copier.c " file?
Hi all,
Where can i get "advanced_boot_copier.c "? In an458 document of niosII_docs_8_0, it guides: "The source code for the default boot copier is included with the Nios II embedded design suite (EDS) in the <Nios II EDS install path>/ components/altera_nios2/boot_loader_sources directory, or in the Nios II literature page ( www.altera.com/literature/lit-nio2.jsp) with this document." But i did not see the source code such "andvanced_boot_copier.c" and "advanced_boot_copier.h " (an458.pdf document is about NIOS boot methods) Thanks for your helps in advance! Konpaba3 Replies
Here you go:
http://www.altera.com/literature/an/an458_design_example_files.zip You have to go to the bottom of the page and expand the "SOPC Builder System Development" section. Jake - Altera_Forum
--- Quote Start --- Here you go: http://www.altera.com/literature/an/an458_design_example_files.zip You have to go to the bottom of the page and expand the "SOPC Builder System Development" section. Jake --- Quote End --- Thanks your very quick, useful reply so much! - Altera_Forum
Thanks you guys, get the example finally almost ten years later. I think if the links of example put in front of an458.pdf will easier for the readers.
