21 years agoWhen do you need to flush icache?
I am writing a bootloader and I am a bit confused on when I need to flush the icache. I've looked at u-boot and it seems to flush the icache after every srec record has been written to memory. Is this overkill? As long as you aren't running the new code yet it seems like you could just call alt_icache_flush_all when you are finished. Any comments?
1 Reply
Hi doleksy,
> I am a bit confused on when I need to flush the icache. You should invalidate the appropriate icache line before executing its code whenever the cache is no longer coherent. For example, if you load an S-Record into memory that contains executable code, you should invalidate the associated icache lines before attempting to execute newly loaded code -- otherwise you might execute the old code that is still resident in the cache. > I've looked at u-boot and it seems to flush the icache after every srec > record has been written to memory. Is this overkill? No -- it's just the strategy chosen by u-boot. Since an srec file does not include any information on whether or not the new data is executable code or not, u-boot makes a conservative assumption: it assumes each srec contains both executable code and data ... and invalidates the icache and flushes the dcache immediately after decoding and writing the srec to memory. Since u-boot can load individual S-Records, it must invalidate/flush the caches as each record arrives -- otherwise you would always need an end record (to know when to flush everything). > As long as you aren't running the new code yet it seems like you could just > call alt_icache_flush_all when you are finished. This would work fine. Regards, --Scott
