14 years agoWhat size is 64K x 16 SRAM ?
dear all, am using this 64k x 16 Cypress SRAM in my qsys design and able to use my nios code in it. I presume the size of this ram is 1 Mbit ie 128 Kbyte but am able to use only 64 Kbyte of the...
14 years agoHi all,
I am getting my quartus code (.sof) flashed correctly using the NIOS II IDE 11.1 - Flash programmer. But the nios code is not getting flashed. i am getting the following warning in problems tab - "WARNING: The expected CPU name does not match the selected target CPU name." and am getting the following messages in processing tab Info: Info: ******************************************************************* Info: Info: Running Quartus II 32-bit Convert_programming_file Info: Info: Command: quartus_cpf --no_banner --convert --device=EPCS128 --option=flash/rpctrl_epcs_flash_controller_0.opt G:/rp_ctrl/rpctrl_q101/rpctrl/rpctrl.sof flash/rpctrl_epcs_flash_controller_0.pof Info: Info: Quartus II 32-bit Convert_programming_file was successful. 0 errors, 0 warnings Info: Info: Peak virtual memory: 150 megabytes Info: Info: Processing ended: Fri Jan 20 10:53:36 2012 Info: Info: Elapsed time: 00:00:05 Info: Info: Total CPU time (on all processors): 00:00:06 Info: Info: ******************************************************************* Info: Info: Running Quartus II 32-bit Convert_programming_file Info: Info: Command: quartus_cpf --no_banner --convert flash/rpctrl_epcs_flash_controller_0.pof flash/rpctrl_epcs_flash_controller_0.rpd Info: Info: Quartus II 32-bit Convert_programming_file was successful. 0 errors, 0 warnings Info: Info: Peak virtual memory: 144 megabytes Info: Info: Processing ended: Fri Jan 20 10:53:40 2012 Info: Info: Elapsed time: 00:00:03 Info: Info: Total CPU time (on all processors): 00:00:04 Info: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Info: Resetting and pausing target processor: OK Info: Reading System ID at address 0x000818E8: verified Info: Info: : Checksumming existing contents Info: Info: 00000000 : Verifying existing contents Info: Info: 00010000 : Verifying existing contents Info: Info: 00020000 : Verifying existing contents Info: Info: 00030000 : Verifying existing contents Info: Info: 00040000 : Verifying existing contents Info: Info: 00050000 : Verifying existing contents Info: Info: 00060000 : Verifying existing contents Info: Info: 00070000 : Verifying existing contents Info: Info: 00080000 : Verifying existing contents Info: Info: 00090000 : Verifying existing contents Info: Info: 000A0000 : Verifying existing contents Info: Info: 000B0000 : Verifying existing contents Info: Info: 00000000 : Reading existing contents Info: Info: 00010000 : Reading existing contents Info: Info: 00020000 : Reading existing contents Info: Info: 00030000 : Reading existing contents Info: Info: 00040000 : Reading existing contents Info: Info: 00050000 : Reading existing contents Info: Info: 00060000 : Reading existing contents Info: Info: 00070000 : Reading existing contents Info: Info: 00080000 : Reading existing contents Info: Info: 00090000 : Reading existing contents Info: Info: 000A0000 : Reading existing contents Info: Info: 000B0000 : Reading existing contents Info: Info: Checksummed/read 44kB in 1.6s Info: Info: 00000000 ( 0%): Erasing Info: Info: 00010000 ( 8%): Erasing Info: Info: 00020000 (16%): Erasing Info: Info: 00030000 (25%): Erasing Info: Info: 00040000 (33%): Erasing Info: Info: 00050000 (41%): Erasing Info: Info: 00060000 (50%): Erasing Info: Info: 00070000 (58%): Erasing Info: Info: 00080000 (66%): Erasing Info: Info: 00090000 (75%): Erasing Info: Info: 000A0000 (83%): Erasing Info: Info: 000B0000 (91%): Erasing Info: Info: Erased 768kB in 7.6s (101.0kB/s) Info: Info: 00000000 ( 0%): Programming Info: Info: 00010000 ( 8%): Programming Info: Info: 00020000 (16%): Programming Info: Info: 00030000 (25%): Programming Info: Info: 00040000 (33%): Programming Info: Info: 00050000 (41%): Programming Info: Info: 00060000 (50%): Programming Info: Info: 00070000 (58%): Programming Info: Info: 00080000 (66%): Programming Info: Info: 00090000 (75%): Programming Info: Info: 000A0000 (83%): Programming Info: Info: 000B0000 (91%): Programming Info: Info: Programmed 725KB +43KB in 18.7s (41.0KB/s) Info: Did not attempt to verify device contents Info: Leaving target processor paused Info: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Info: Resetting and pausing target processor: OK Info: Reading System ID at address 0x000818E8: verified Info: Info: : Checksumming existing contents Info: Info: 000B0000 : Verifying existing contents Info: Info: 000C0000 : Verifying existing contents Info: Info: 000B0000 : Reading existing contents Info: Info: 000C0000 : Reading existing contents Info: Info: Checksummed/read 58kB in 1.7s Info: Info: 000B0000 ( 0%): Erasing Info: Info: 000C0000 (50%): Erasing Info: Info: Erased 128kB in 1.3s (98.4kB/s) Info: Info: 000B0000 ( 0%): Programming Info: Info: 000C0000 (50%): Programming Info: Info: Programmed 71KB +57KB in 2.1s (60.9KB/s) Info: Did not attempt to verify device contents Info: Leaving target processor paused I am testing with a Char LCD code.. i am not getting the processor to start. I have tested the same code with SRAM and On-Chip memory for the program memory, same result Please help.
