14 years agoWhat size is 64K x 16 SRAM ?
dear all, am using this 64k x 16 Cypress SRAM in my qsys design and able to use my nios code in it. I presume the size of this ram is 1 Mbit ie 128 Kbyte but am able to use only 64 Kbyte of the...
14 years agoThe generated interface always presents a byte address. Then, if you use a 16bit wide device without byte enables you must discard A0 and connect Qsys A16-A1 to SRAM A15-A0.
