What is the most direct way to program an eMMC chip on the HPS controller?
Thanks for your reply,
I have looked at that thread before. I see many users with same issue, but I see no elegant solution.
Usually, when using an eMMC chip, it involves a file-system, which means that a complete SD-card image must be transferred. This is often a few GB, which makes Jtag impractical.
I have only tried the method with U-boot and the debugger.
Our application is a bear-metal application, although we are using FreeRTOS for the Ethernet stack. Therefore I find the Linux method very indirect.
Shortly after posting this question, I found a combination of these methods:
https://rocketboards.org/foswiki/Documentation/Arria10NANDFlashProgramming
As I understand this, U-boot has a tftp-client and is capable of writing to the eMMC chip.
For me as Engineer, many things are possible, but I have to find a solution, which can be used in the production. Ideally, it is a script/program, which handle all the complicated stuff.
/Magnus
