rbris's avatar
rbris
8 years ago
What file do I need to #include to enable the jamStub.c file to compile in my quest to port the jam Player SW into my embedded system? What file do I need to #include to complete the build?
I am trying to port the Jam Player I downloaded from www.jamisp.com to our system's embedded processor.
I edited the #define to EMBEDDED (as instructed in AN 122). But, when I build the project, jamStub.c does not compile. The reason is that I am missing about 20 I/O related functions, such as read(), write(), fprintf(). These are all functions that probably should be in stdio.h, but are not. Where are these functions defined? I have looked for them but cannot find any. I assume they are in a file, but I don't know the file name. What #include am I missing? Where can I find these files?
  • rbris's avatar
    rbris
    Nooraini, Thanks so much. I will fetch the JAM STAPL player from the link you gave me and get back to you if I still have a problem building the code. Best regards, RABrisk
  • rbris's avatar
    rbris
    Nooraini, Thank you for your email with its URL. I downloaded the files from the URL you sent me. I followed the ReadMe instructions (as before) then created a project using the .C files from the download. (NOTE: There are only 4 “.C” files in the files I downloaded from your URL. There were 12 in the other download). I changed the PORT from WINDOWS to EMBEDDED. I commented out those .H files that the build complained it could not open. I built the project. Eventually, the build got down to exactly the same result as the other code I downloaded. Both builds have 3 errors and 33 warnings that I need to eliminate to achieve a successful build. The issues are: o Error[Pe020]: identifier "FILE" is undefined C:\JAM STAPL player jbi22\jbi_22\code\JBISTUB.C 866 o Error[Pe020]: identifier "fp" is undefined C:\JAM STAPL player jbi22\jbi_22\code\JBISTUB.C 866 o Error[Pe070]: incomplete type is not allowed C:\JAM STAPL player jbi22\jbi_22\code\JBISTUB.C 867 o Warning[Pe223]: function "fprintf" declared implicitly C:\JAM STAPL player jbi22\jbi_22\code\JBISTUB.C 885 o . . . o Warning[Pe223]: function "fopen" declared implicitly C:\JAM STAPL player jbi22\jbi_22\code\JBISTUB.C 1051 o etc. . . . So, my question remains the same. Where do I get the functions and definitions required to eliminate the remaining 3 errors and 33 warnings? Best regards, RABrisk
  • Nooraini_Y_Intel's avatar
    Nooraini_Y_Intel
    Base on this URL link www.jamisp.com, I don't think this link is part of Intel(Altera) page. Thus any files or software tools posted from this link is not supported by Intel (Altera). I couldn't even access this link www.jamisp.com as it keep timing out.
    All the require files are already in published the Altera JAM STAPL player source code from the link below:
    https://www.intel.com/content/www/us/en/programmable/support/support-resources/download/programming/jam.html
    As you can observe from the table the Jam STAPL Byte-Code Compiler v2.4 is the last version from year 2005. There are no other updated version as theses software are mature and consider EOL.
    Nooraini
