14 years agoWhat can uclinux do?
Hi, I want to import the OpenCV library in NiosII. And I found a thread here: http://www.alteraforum.com/forum/showthread.php?t=22856&highlight=opencv In this thread, parrado s...
14 years agoMost libraries and application are written to be used on an operating system such as Linux, so porting is likely to be a lot easier if you are using one. The Nios II Linux distribution uses the same Linux kernel as your Linux desktop, but for the Nios II architecture, so porting many libraries is simple.
