14 years agoWeak pull-up resistors
Hi everyone! I enabled weak pull-ups for the input and output pin (cyclone II device). But when I measure the voltage on these pins, on the input pin is 3V and on the output pin is 0V. Shouldn...
14 years agoHi dsl, thanks for joining in to help me. That is the thing that I found strange when I started using the peripheral. When I connected it first to fpga without applying the power to it, I saw it was back-powered from the input lines. Can that cause a damage to the device? If the output of the peripheral is high and the input of the fpga is tri-stated, can that make a problem too?
