14 years agoWeak pull-up resistors
Hi everyone! I enabled weak pull-ups for the input and output pin (cyclone II device). But when I measure the voltage on these pins, on the input pin is 3V and on the output pin is 0V. Shouldn...
14 years agoHello Dave,
Thanks for the suggestion. When I drive it high, i.e. instead of 'Z' I write '1', the pin is initially 3.3V. What I also found out is that for SOPC builder components, I cannot define initial states like that. For instance, when I use SPI interface with Clock polarity = 1, Clock phase = 1, after programming the device, only SSn and SCLK are 3.3V. MISO is 3V and MOSI is 0V. MOSI becomes 3.3V in the idle state only after sending a byte via SPI. I have to figure out now how I can set all the lines to be 3.3V from the beginning. Nikola
