14 years agoWeak pull-up resistors
Hi everyone! I enabled weak pull-ups for the input and output pin (cyclone II device). But when I measure the voltage on these pins, on the input pin is 3V and on the output pin is 0V. Shouldn...
14 years agoHi Nikola,
--- Quote Start --- I defined the pin in the entity as GPIO: OUT STD_LOGIC := 'Z' and after programming the device, the output pin is pulled to 3V. --- Quote End --- Great! --- Quote Start --- I still wonder why it is not pulled to 3.3V, but anyway it is still better than pulling it to GND. --- Quote End --- Try driving it high; is it still 3.0V or is it closer to 3.3V? Cheers, Dave
