14 years agoWeak pull-up resistors
Hi everyone! I enabled weak pull-ups for the input and output pin (cyclone II device). But when I measure the voltage on these pins, on the input pin is 3V and on the output pin is 0V. Shouldn...
14 years ago --- Quote Start --- After compiling the project, there is one warning about the output pin that says: "Output pin is stuck at GND". --- Quote End --- Then it sounds like you have an output defined, but you have left it undriven, so Quartus has provided a default for you. Try this instead: unused_output <= 'Z'; Quartus will then warn you that it has used a permanently disabled tri-state. However, this will force your output to be tri-stated, and your weak pull-up will pull it high. Cheers, Dave
