14 years agoWeak pull-up resistors
Hi everyone! I enabled weak pull-ups for the input and output pin (cyclone II device). But when I measure the voltage on these pins, on the input pin is 3V and on the output pin is 0V. Shouldn...
14 years agoif you're driving the output low that would be the expected behavior
my initial thought was that weak pull up resistors only work on inputs, but i don't see anything in the documentation that actually says that what are you trying to do with pull ups on the outputs?
