SKuma36
7 years agoWe are not getting proper data when we do a read access to the on-chip memory via the AXI interface.
Hi, We are using Arria10 FPGA to implement our custom IP controller. The controller has both AHB slave as well as AXI master interfaces. The controller's registers are accessed using NIOS II Process...
KennyT_altera
7 years agoIt should be fine, what you need to check is the interconnect whether it is make sense.
You can refer to https://www.youtube.com/watch?v=LdD2B1x-5vo
It teaches you how to check the interconnect.
