SKuma36
7 years agoWe are not getting proper data when we do a read access to the on-chip memory via the AXI interface.
Hi, We are using Arria10 FPGA to implement our custom IP controller. The controller has both AHB slave as well as AXI master interfaces. The controller's registers are accessed using NIOS II Process...
KennyT_altera
7 years agoDid you attached the signal tap snapshot? I cant see it from my side. Btw, you have all your timing close right?
- SKuma367 years ago
SignalTap snapshot attached...yes, the bitstream is timing closed.
