14 years agowahen i flash my zimage on flash memory , i can't use telnet
hi all
please , i use µclunix , when i flash the zimage in flash memory ans i desactive the JTAG UART , i can't use telnet , in my file RC , i add inetd& --- Quote Start --- hostname uClinux mount -t proc proc /proc -o noexec,nosuid,nodev mount -t sysfs sysfs /sys -o noexec,nosuid,nodev mount -t devpts devpts /dev/pts -o noexec,nosuid mount -t usbfs none /proc/bus/usb mkdir /var/tmp mkdir /var/log mkdir /var/run mkdir /var/lock mkdir /var/empty ifconfig lo 127.0.0.1 route add -net 127.0.0.0 netmask 255.0.0.0 lo# dhcpcd -p -a eth0 & cat /etc/motd mknoddev ifconfig eth0 192.168.10.180 inetd& --- Quote End --- but when i flash my Zimage in RAM , i can use telnet withou any problem please, if someone have an idea , or if there is other configuartion to be able to use the telnet , I realy need it thank's4 Replies
What if you
disable the JTAG UART and run from RAM? enable the JTAG UART and run from flash? - Altera_Forum
I have the same problem,
I write sof in EPCS and program in CFI --- Quote Start --- sof2flash --epcs --input=<chemin>/irp.sof --output=fpga_sof.flash elf2flash --base=0x02800000 --end=0x02FFFFFF --reset=0x02800000 --input=zImage --output=uc_flash.flash --boot=<chemin>/Altera/nios2eds/components/altera_nios2/boot_loader_cfi.srec nios2-flash-programmer --epcs --base=0x03001800 fpga_sof.flash nios2-flash-programmer --base=0x02800000 uc_flash.flash --- Quote End --- uc_flash.flash = 6MBytes, so i changed Processor type and features--> Link address offset for booting from 0x00500000 to 0x01555555 (2/3 of my 32M sdram) I also changed rc file --- Quote Start --- hostname uClinux mount -t proc proc /proc -o noexec,nosuid,nodev mount -t sysfs sysfs /sys -o noexec,nosuid,nodev mount -t devpts devpts /dev/pts -o noexec,nosuid mount -t usbfs none /proc/bus/usb mkdir /var/tmp mkdir /var/log mkdir /var/run mkdir /var/lock mkdir /var/empty ifconfig lo 127.0.0.1 route add -net 127.0.0.0 netmask 255.0.0.0 lo# dhcpcd -p -a eth0 & cat /etc/motd mknoddev ifconfig eth0 192.168.10.170 inetd& --- Quote End --- After reboot, ping 192.168.10.170 work but not telnet (I disabled the JTAG UART and i have 2 uart in sopc used for my application) Thanks for help - Altera_Forum
if you disable "Support for console on Altera JTAG UART" only it dosen't work
but if you add Bypass output when no connection it work for me :) - Altera_Forum
yessss it work thanks hayder and ykozlov (http://www.alteraforum.com/forum/member.php?u=26158)
