16 years agoVoIP (AN374) questions
Hi all, 1) Firstly, I worked on a 3C40 FPGA devboard with a 1Gbe Marvell 88E1119R PHY. At this time, I have a fully functionnal uClinux + Boa webserver system using Opencores 10/100 MAC, a...
15 years agohello guys.........
i just have the an374 working with a uclinux cpu with boa server to configure the an374..........is finished and working i had some problems like you --- Quote Start --- The video appears but with a high degree of artefacts (green square all over the screen) and when I check the statistics, the number of corrupted packets is very elevated !! --- Quote End --- try look your ts packet size 188 or 204 .....you need detect and if change you need reset the ts input buffer...... monitore the signal named ts_valid[0] and ts_data at ts input buffer in signal tap good luck Franz Wagner
