16 years agoVoIP (AN374) questions
Hi all, 1) Firstly, I worked on a 3C40 FPGA devboard with a 1Gbe Marvell 88E1119R PHY. At this time, I have a fully functionnal uClinux + Boa webserver system using Opencores 10/100 MAC, a...
16 years ago --- Quote Start --- + Is it possible to use the altera tse mac in the same time with uclinux (LAN --> webserver and webserver --> LAN) and with the data path (RTP + UDP/IP --> LAN) ??? What happened if uClinux and UDP/IP block sends data simultaneously to the MAC ??? --- Quote End --- Tried and am getting simultaneous data to MAC - did I miss this workaround?
