15 years agoVerilog - minimizing logic
Hi I'm generating some asymmetric waveforms from a counter, and am able to adjust the counts where it changes output. Hence I'd like to choose numbers that utilize the minimum amount of logic ...
15 years agoThis kind of compare logic is minimized if you choose numbers which allow comparision of a limited number of bits.
This can be easily evaluated from the binary representation of you numbers, e.g (Counter1 >= 128) && (Counter1 < 176) is efficient because only 3 upper bits need to be compared in order to evaluate the expression. While (Counter1 >= 135) && (Counter1 < 182) would require far more complex logic.
