15 years agoVerify failed between address 0x10000 and 0x10993 in onchip_memory
Hi all,
I am using Quartus II 10.1 and NIOS II SBT, and am trying to build a "hello_world" sample NIOS II project on DE0_NANO board (Cyclone IV E: EP4CE22F17C6). In SOPC Builder, I added "cpu/sysid/jtag_uart/onchip_memory/Parallel IOs". I encountered the error when I was trying to download the "hello_world" project to the board. After I typed the command "nios2-download hello_wolrd.elf -g ; nios2_terminal.exe" in the GCC4 window. An error message occured as shown below, and stopped there: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Initializing CPU cache <if present> OK Downloaded 28KB in 0.5s <56.0KB/S> Verifying 00010000 <91%> Verify failed between addresses 0x10000 and 0x10993 Leaving target processor paused nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0 nios2-terminal: <Use the IDE stop button or Ctrl-C to terminate> Has anyone ever had similar issues before? Please give me some pointers! Thanks, Tina1 Reply
Hi
I am facing the same issue now. Can you tell me how u solved it?
