14 years agoVerified OK - Leaving target processor paused
I have got a problem when running Nios, here is my problem: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Initializing CPU cache (if present) OK ...
14 years agoThis could be a pin assignment issue. Ensure that clk and reset are connected to the respective pins in the board.
For DE4, I found that assigning clk to pin OSC_50_B7 (50 Mhz clk input for Bank 7c 1.8v pin A19) worked. Also, I think the frequency of clk input from board must match frequency in SOPC builder (50MHz usually) unless you are using an exclusive PLL
