14 years agoVerified OK - Leaving target processor paused
I have got a problem when running Nios, here is my problem: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Initializing CPU cache (if present) OK ...
14 years agoHow do you download the .elf file to the Nios? If using the command line you need to add the -g option to start the CPU after download. If you are using a GUI there may be a box to tick to do that.
