17 years agovendor_hwselect - error 2
******************************************************************************** ***************************************************** [root@localhost uClinux-dist]# make vendor_hwselect SYSPTF=...
14 years agoHi
I revd following errors while compiling. I am unable to figure out what is problem. My design compiled correctly. make vendor_hwselect SYSPTF=/media/96A00F1FA00F0609/altera/temp/try1.ptf make ARCH=nios2 -C vendors vendor_hwselect make[1]: Entering directory `/home/elysium/uclinux/nios2-linux/uClinux-dist/vendors' make -C /home/elysium/uclinux/nios2-linux/uClinux-dist/vendors/Altera/nios2/. dir_v=/home/elysium/uclinux/nios2-linux/uClinux-dist/vendors/Altera/nios2/. -f /home/elysium/uclinux/nios2-linux/uClinux-dist/vendors/vendors-common.mak vendor_hwselect make[2]: Entering directory `/home/elysium/uclinux/nios2-linux/uClinux-dist/vendors/Altera/nios2' [ -d /home/elysium/uclinux/nios2-linux/uClinux-dist/romfs/$i ] || mkdir -p /home/elysium/uclinux/nios2-linux/uClinux-dist/romfs make ARCH=nios2 CROSS_COMPILE=nios2-linux-uclibc- -C /home/elysium/uclinux/nios2-linux/uClinux-dist/../linux-2.6 O=/home/elysium/uclinux/nios2-linux/uClinux-dist/linux-2.6.x hwselect make[3]: Entering directory `/home/elysium/uclinux/nios2-linux/linux-2.6' GEN /home/elysium/uclinux/nios2-linux/uClinux-dist/linux-2.6.x/Makefile scripts/kconfig/conf -s arch/nios2/Kconfig# # configuration written to .config# make[4]: *** No rule to make target `hwselect'. Stop. make[3]: *** [sub-make] Error 2 make[3]: Leaving directory `/home/elysium/uclinux/nios2-linux/linux-2.6' make[2]: *** [vendor_hwselect] Error 2 make[2]: Leaving directory `/home/elysium/uclinux/nios2-linux/uClinux-dist/vendors/Altera/nios2' make[1]: *** [vendor_hwselect] Error 2 make[1]: Leaving directory `/home/elysium/uclinux/nios2-linux/uClinux-dist/vendors' make: *** [vendor_hwselect] Error 2 I think CROSS COMPILER is not nios2-linux-uclibc- hwselect. Any help?
