16 years agoVectored Interrupt Controller implementation
Sorry if this is a basic question, but I couldn't find an answer in the literature or forum. I've implemented a VIC in the SOPC Builder, but after generation I now have a d_irq_to_the_cpu_0 in...
16 years agoWell it seems I was doing something unique, and I thought I'd share. After speaking with Altera customer support, I received the following solution:
--- Quote Start --- Good news… I found the root caused for this issue, the d_irq_to_the_cpu_o port will generated when the VIC is connected to output clock from PLL core instead of ALTPLL. Please see attachment for more information. Workaround: Use ALTPLL in SOPC Builder. http://www.altera.com/literature/hb/nios2/n2cpu_nii53002.pdf This issue might be VIC bug; I will submit the bug report for our R&D team to deep investigation. Thanks for bringing this to our attention and I sincerely hope that we may serve in more convenient way in the future. --- Quote End --- After this fix, the project wouldn't compile correctly with a handful of errors similar to: --- Quote Start --- Error: PLL "pll" uses test only parameter c0_test_source, but parameter must only be used in test mode --- Quote End --- After speaking with customer service again, I received an additional solution which allows me to compile correctly: --- Quote Start --- I tried to debug this issue, and below were the methods: 1. Remove PLL in SOPC, regenerate, update symbol, recompile: failed 2. Remove PLL & ALTPLL in SOPC, regenerate, update symbol, recompile: passed 3. From Step2, Insert the altpll megafunction on the top level, and connect the output clock to SOPC symbol block: Passed (archieve project attached) 4. Add back the ALTPLL in SOPC from step 3, regenerate, update symbol, recompile: Failed 5. Also, I tried to create a new project in Quartus II with the same components as your project, and regenerate & recompile: Passed I suspected this issue is created by the old PLL with ALTPLL in a SOPC project. --- Quote End ---
