14 years agouuid.h/luuid problem, please help
sory for annoying topic, but i've tried all possible solutions in the forum. After ./update I cannot compile a simple kernel. First i recieved a uuid.h not found error during compilation. I made a research and found that the problem was in the absence of uuid-devel package, so I reinstalled it. But this hasn't helped. So i found uuid.h file in /usr/include and put it in the required directory under ../uClinux-dist/user/mtd-utils/.../include/uuid/ and the error gone, but another one has come up: CHK include/version.h
LD mkfs.ubifs/mkfs.ubifs
/usr/bin/ld: cannot find -luuid
collect2: ld returned 1 exit status
make: *** Error 1
make: Leaving directory `/home/Vasek/linux_tools/nios2-linux/uClinux-dist/user/mtd-utils/36d8de81049c9c908740b690c664b5bd3703ccd6'
make: *** Error 2
make: Leaving directory `/home/Vasek/linux_tools/nios2-linux/uClinux-dist/user/mtd-utils'
make: *** Error 2
make: Leaving directory `/home/Vasek/linux_tools/nios2-linux/uClinux-dist/user'
make: *** Error 2
make: *** Error 1
I'm at the unstable-nios2mmu branch in linux-2.6 and at trunk in uClinux-dist. Please, help. What am I doing wrong?2 Replies
The linker says "I searched the library 'libuuid.a' or 'libuuid.so', but I couldn't find it". So please try Library Configuration ---> <select> --- *** Additional Blackfin dist libs *** .......... [ ] Build dmalloc [* ] Build e2fsprogs-libs [ ] Build eXosip .......... . KazuCHK include/version.h LD mkfs.ubifs/mkfs.ubifs /usr/bin/ld: cannot find -luuid - Altera_Forum
Hi Kazu,
thank you very much for your help. Actually I haven't tried your solution, but switching to the nios2 branch (i was at unstable-nios2mmu before), updating and reinstalling e2fsprogs-devel package did the job. Thanks again. Now I can move forward.
