10 years agousing UART in DE1-SoC board
Hi, I am using a DE1-SoC board. I am trying to hands-on few basic projects. My question is, can I not use the UART to visualize the output directly, instead of using it with a Nios II core or t...
10 years agoyes there is, assuming your counter counts slower than your uart takes to send or you are not intrested in all the values. However a uart is not one of the first projects I would suggest to a beginner. It is relatively easy to create but you need a few basic skills. Do you have leds? Those are much easier to use but you might want to slow down the clock to see it coumt on the lsb's.
