19 years ago
Using redboot with x/y modem
I am trying to use redboot but I'm a bit stuck. The first thing I want to try to do is simply to download an executable into RAM over an RS232 link and then run it. I have built redboot by using the the default settings and then adding the -G0 global compiler flag, setting the debug device to "none" and the console device to "dev/uart1" (I made those changes after reading other posts about redboot in this forum). I am using a Nios II, Cyclone II dev kit.
I have manged to program redboot into flash and when I reset the board I get a redboot prompt in Hyperterminal - so far so good! When I try to download a file using either "load - m xmodem" or "load -m ymodem" I get various error messages. I am using the "send file" tool in HyperTerminal. I have also tried reducing the baud rate from 115000 to 9600. At the slower baud rate I still get the redboot prompt but the errors are the same.
I have noticed that this problem has been discussed in a few other posts, but there are no solutions posted. I am sure that some of you know how to make this work. Is there a secret trick?
Mike
    Hi.
    I had sucess in downloading program by x/y modem of redboot.
    Also, runing RAM Applicaiton program by redboot..
    I have changed UART1 baudrate to 57600 by SOPC builder, and modified altera_avalon_uart_comm.c's altera_avalon_uart_diag_getc_timeout () functions in eCos driver.
    typedef struct
    cyg_uint8* port;
    cyg_uint32 irq;
    //Add by JYKoh
    cyg_int32 msec_timeout;
    //End
    } altera_avalon_uart_chan;
    cyg_bool altera_avalon_uart_diag_getc_timeout(void* __ch_data, cyg_uint8* ch)
    int delay_count;
    //Add By JYKoh
    altera_avalon_uart_chan* chan = (altera_avalon_uart_chan*)__ch_data;
    //End
    cyg_bool res;
    CYGARC_HAL_SAVE_GP();
    //Chg by JYKoh
    // delay_count = 10; // delay in .1 ms steps
    delay_count = chan->msec_timeout * 10; // delay in .1 ms steps
    //End
    for(;;) {
    res = altera_avalon_uart_diag_getc_nonblock(__ch_data, ch);
    if (res || 0 == delay_count--)
    break;
    //Chg by JYKoh
    // HAL_DELAY_US(10);
    HAL_DELAY_US(100);
    //End
    CYGARC_HAL_RESTORE_GP();
    return res;
    int altera_avalon_uart_diag_control(void *__ch_data, __comm_control_cmd_t __func, ...)
    static int irq_state = 0;
    altera_avalon_uart_chan* chan;
    int ret = 0;
    cyg_uint32 ctrl;
    //Add by JYKoh
    case __COMMCTL_SET_TIMEOUT:
    va_list ap;
    va_start(ap, __func);
    ret = chan->msec_timeout;
    chan->msec_timeout = va_arg(ap, cyg_uint32);
    va_end(ap);
    //End
    default:
    break;
    return ret;
    Hi Kohjy,
    Thanks for posting that solution. Now that I have learned how to use u-boot I have decided that I like it so much that I will keep using it, it's really quite cool!
    Mike
