Using GCC compiler warning "-Wempty-body"
I added -Wextra to my build to make the code cleaner. But I get an "Empty body in an else statement" warning which -Wextra does enable (see: http://gcc.gnu.org/onlinedocs/gcc/warning-options.html#warning-options).
So I added -Wno-empty-body to the NIOS II compiler warnings text line and I get this error: cc1.exe: error: unrecognized command line option "-Wno-empty-body". I also get the error using -Wempty-body. So the question is, what is the right option for this warning? Thanks, Bill6 Replies
Check the documentation for the version of gcc you are using, -Wempty-body is probably a very new option.
I thought that might be the case. I know the NIOS II GCC compiler (4.x?) is behind the latest GCC release. So does this mean the NIOS II GCC compiler generates the warning without any way to disable it?
Thanks dsl! Bill - Altera_Forum
A quick look in the gcc sources (having repoduced the error message with a random gcc 4.1.2 since you misquoted it) shows it being generated in c_finish_if_stmt() in c-typeck.c.
The code is inside 'if (extra_warnings)' - probably set by -Wextra, and is:
Compare this against, a few lines higher:warning (0, "%Hempty body in an else-statement", EXPR_LOCUS (*inner_else));
My guess is that the first argument to warning() maps onto the flag to enable/disable the warning. So you are probably out of luck.warning (OPT_Wparentheses, "%Hsuggest explicit braces to avoid ambiguous %<else%>", &if_locus); - Altera_Forum
Wow, thanks for the research! Much appreciated. I think you're right - the 0 argument is telling. I guess the next step is to explicitly call out the -W options excluding empty_body that -Wextra turns on. Like:
I tried the above options. LOL - 7 of these aren't recognized! Oh well. Thanks again, Bill-Wclobbered -Wignored-qualifiers -Wmissing-field-initializers -Wmissing-parameter-type -Wold-style-declaration -Woverride-init -Wsign-compare -Wtype-limits -Wuninitialized -Wunused-parameter -Wunused-but-set-parameter - Altera_Forum
There is an option to the compiler to list the known -W (etc) options.
The gcc docs web site does have info for (some) older versions. - Altera_Forum
missing-field-initialisers and unused-parameter are somewhat horrid, fixing 'sign-compare' is bad enough
