14 years agoUsing FPU with uCLinux
Hello folks, i'am just trying to use the floating-point-unit within my uCLinux dist. I have added the corresponding custom instruction to the cpu within my sopc-builder system. After that i co...
14 years agoThank you for your replys.
I have an application, where i need to implement some floating-point operations. I have just started with uCLinux dist. I only got a little bit confused, because MUL and DIV hardware is recognized and also displayed by the cpuinfo but FPU not. So i will try to compile some benchmark applications with and without FPU to figure out the performance impact.... By the way: How do you compile your User-Space application? I would like to do this via Eclipse...Any experience about this? How can i place simple files (eg. sh-scripts) into the initial file-system?
