15 years agoUsing EPCS and CFI for booting - failure
Hi guys, I'm in a real trouble and now after 5 days still do not see any solution. The situation is that I have a an eval board from EVB with CIII. On the board there is an EPCS and a CFI flash...
15 years agoHi alibiman:
My guess is the nios boot loader is looking at the epcs instead of the CFI flash. Have you tried loading a small "led blink" style program into the EPCS instead of the CFI? If that works, you could write a small bootloader that's stored in the EPCS that then causes the CFI flash to be loaded and started. Pete
