9 years agoUsing EPCQ to load Nios
1) Why can't I get past "No EPCS registers found"? If I try "nios2-flash-programmer --device=1 --base=0x42000000 --epcs --debug" I get: Using cable "USB-Blaster [USB-0]", device 1, instance 0x...
9 years agoHi,
It sounds a bit confusing to me. Are you using EPCS or EPCQ? The nios2-flash-programmer should works fine for EPCS but it may not work well for certain EPCQ devices with larger memory >256Mb. Regards, CH
