9 years agoUsing EPCQ to load Nios
1) Why can't I get past "No EPCS registers found"? If I try "nios2-flash-programmer --device=1 --base=0x42000000 --epcs --debug" I get: Using cable "USB-Blaster [USB-0]", device 1, instance 0x...
9 years agoHmm..you are using Nios II Flash Programmer. Could you switch to Quartus II Programmer to flash your epcs?
Which device are you using? Refer to this document: https://www.altera.com/en_us/pdfs/literature/an/an736.pdf
