15 years agoUsing custom instruction from uCLinux user app on nios2mmu
Hello, Is it possible to use a custom instruction from an user application running on NIOS2MMU - uCLinux. I'm trying to run the CRC design example on uCLinux. When I try to compile the ...
15 years agoAFAIK, an instruction can use registers that are modified by the previous one (at least for calculations, maybe when used as an address in a load or store instruction this might cause a hazard and thus stall the pipeline).
So there seems to be a shortcut for the register values and they don't need to be physically saved before being read by the next instruction. -Michael
