15 years agoUsing custom instruction from uCLinux user app on nios2mmu
Hello, Is it possible to use a custom instruction from an user application running on NIOS2MMU - uCLinux. I'm trying to run the CRC design example on uCLinux. When I try to compile the ...
15 years ago --- Quote Start --- If you have a buffer, then you want a dma based engine.... --- Quote End --- +1 -Michael
