19 years agoUsing cable "USB-Blaster [USB-0]", device 1, insta
Hi, everyone, I met a strange problem. After I compiled the project(standard project, I added usb host IP core and assign pins) in Quartus II 5.0 successfully, and download the .sof file into t...
19 years agoThanks, guys!
<div class='quotetop'>QUOTE </div> --- Quote Start --- I had the same problem... I had made mistakes in pin assignments and that was the error. make sure all pin assignments are correct[/b] --- Quote End --- I check the pin assignment very carefully, but the error comes again! <div class='quotetop'>QUOTE </div> --- Quote Start --- I have the same problem. I have an Altera DE1 Board. I downloaded more then one time the sof file and Nios and I got each time the same problem. I'm using NIOS II with only onchip memory and JTAG communication. So I think this problem couldn't be caused by the SDRAM. Ideas to solve the problem?[/b] --- Quote End --- Not yet util now!
