13 years ago
Using 2 timers ?
We are trying to use 2 interval timer (200ms and 500ms) on a nios 2 processor. One is configure as a system clock timer and its work fine., but the second don’t work.
The declaration on the nios is (for the two interval timer) :
alt_irq_enable(TIMER_500M_IRQ
IOWR(TIMER_500M_IRQ, 1, 3);
alt_irq_register( TIMER_500M_IRQ, null, TIMER500M_IRQ);
The interrupt function look like that :
static void TIMER500M_IRQ(void* context, alt_u32 id)
IOWR(TIMER_500M_BASE, 0, 0);
//code
Does anyone have a solution a this problem ?
Thanks in advance.
    We need to quickly finish our project (with a single timer use).
    So, we will make other tests with your suggestions at the end of the next week.
    We let you informed.
    Thank you.
    We have made several tests today, and the problem was solved. In fact it was easy, we have made a mistake during addressing the register and the during of the function of the timer is longer than the period of the timer. Below a code example for other user of this forum :
    // Declaration of the timer (500ms)
    IOWR_ALTERA_AVALON_TIMER_CONTROL(TIMER_500M_BASE, 0);
    IOWR_ALTERA_AVALON_TIMER_PERIODL(TIMER_500M_BASE, 0x9680);
    IOWR_ALTERA_AVALON_TIMER_PERIODH(TIMER_500M_BASE, 0x0098);
    ALTERA_AVALON_TIMER_CONTROL_CONT_MSK
    | ALTERA_AVALON_TIMER_CONTROL_START_MSK
    | ALTERA_AVALON_TIMER_CONTROL_ITO_MSK);
    // Snapshot
    IOWR_ALTERA_AVALON_TIMER_SNAPL(TIMER_500M_BASE, 0x00);
    periodl=IORD_ALTERA_AVALON_TIMER_SNAPL(TIMER_500M_BASE);
    periodh=IORD_ALTERA_AVALON_TIMER_SNAPH(TIMER_500M_BASE);
    Thanks again for your help.
