14 years agoUsing 2 timers ?
We are trying to use 2 interval timer (200ms and 500ms) on a nios 2 processor. One is configure as a system clock timer and its work fine., but the second don’t ...
14 years agoMy code sample is the same of yours, except the different timer name.
--- Quote Start --- Only one timer works and we can’t read the period programmed --- Quote End --- Even if timer doesn't work, you should be able to read back the programmed period. This is very strange: timer is one of the simplest devices, very easy to work with. Are you sure there is no timing issues in fpga configurations? Is your design correctly constrained?
