21 years ago
User Logic interfacing?
I'm just starting to try to integrate some user logic with a NiosII core. I have read round this
quite a bit, including searching here but still have a few questions.
I have the following interfaces at the top of my module that I need the CPU to be able to read and
write to..
din : in std_logic_vector(15 downto 0); -- writedata
wr : in std_logic; -- write
op_enable : in std_logic; -- writedata
op_polarity : in std_logic; -- writedata
int_en : in std_logic; -- writedata
empty_flag : out std_logic; -- readdata
empty_intrpt : out std_logic; -- irq
buffer_size : out std_logic_vector(9 downto 0) -- readdata
I have tried integrating this using the 'Interface to User Logic' Legacy component, defining each interface as above.
I have 6 read or write elements, but when SOPC builder created the component it only allocated 4 addresses
for the component.
Has it lumped ports into the same address? (As an aside, I presume it's more efficient for me to concatenate
signal lines internally and provide fewer interface ports allowing the SW to identify the relevant bits).
How do I know what's been allocated to which address?
I'd like the interrupt to be edge triggered. When adding a PIO port you're given the option to select how the
interrupt is raised. How is this defined for user logic?
Thanks for any help with this, the documentation covering this doesn't seem clear and consise, and what
there is is scattered far and wide (cue someone to post a link to an easily found idiots guide to user
logic interfacing).
Nial.
