10 years agoUse DS-5 AE Bare-metal for C code programming on DE0-NANO_SOC
I am trying to use DS-5 AE Evaluation for C code programming on DE0-NANO_SOC. when I load preloader the following message will be appeared: Stopping running target Altera - Cyclone V SoC (Dual Core) on TCP:localhost on connection Connected to running target Altera - Cyclone V SoC (Dual Core) on TCP:localhost Execution stopped at: S:0x00002FA8 source /v "C:\altera\15.0\embedded\ds-5\sw\debugger\configdb\Scripts\altera_target_check .py" S:0x00002FA8 TST r1,#4 No SYSID registers could be found. Has a peripheral description file been supplied? load "C:\altra_trn\DE0_Nano_SOC_Pro\DE0_NANO_SOC_GHRD\W orkSpace5\test\u-boot-spl" Loaded section .text: S:0xFFFF0000 ~ S:0xFFFF6AA3 (size 0x6AA4) Loaded section .rodata: S:0xFFFF6AA4 ~ S:0xFFFF8672 (size 0x1BCF) Loaded section .data: S:0xFFFF8678 ~ S:0xFFFF954B (size 0xED4) Entry point S:0xFFFF0000 cd "C:\altra_trn\DE0_Nano_SOC_Pro\DE0_NANO_SOC_GHRD\W orkSpace5" Working directory "C:\altra_trn\DE0_Nano_SOC_Pro\DE0_NANO_SOC_GHRD\W orkSpace5" set debug-from *$ENTRYPOINT start Starting target with no symbolic information loaded Execution stopped at: S:0xFFFF0000 wait S:0xFFFF0000 B {pc}+0x70 ; 0xffff0070 Run Starting target with no symbolic information loaded Pause 1s Interrupt Execution stopped at: S:0xFFFF475C S:0xFFFF475C B {pc} ; 0xffff475c Quit Disconnected from stopped target Altera - Cyclone V SoC (Dual Core) on TCP:localhost but The following problem will be appeared for loading test.axf: Stopping running target Altera - Cyclone V SoC (Dual Core) on TCP:localhost on connection Connected to running target Altera - Cyclone V SoC (Dual Core) on TCP:localhost Execution stopped at: S:0x00002FA8 source /v "C:\altera\15.0\embedded\ds-5\sw\debugger\configdb\Scripts\altera_target_check .py" S:0x00002FA8 TST r1,#4 No SYSID registers could be found. Has a peripheral description file been supplied? loadfile "C:\altra_trn\DE0_Nano_SOC_Pro\DE0_NANO_SOC_GHRD\W orkSpace5\test\Debug\test.axf" ERROR(CMD16-TAD274-NAL22): ! Failed to load "test.axf" ! Failed to write 4,884 bytes to address S:0x00200000 while writing block of 4,096 bytes to address S:0x00200000 ! General error on memory or register access. cd "C:\altra_trn\DE0_Nano_SOC_Pro\DE0_NANO_SOC_GHRD\W orkSpace5" Working directory "C:\altra_trn\DE0_Nano_SOC_Pro\DE0_NANO_SOC_GHRD\W orkSpace5" set debug-from main start WARNING(CMD399-COR168): ! Failed to start the target ! No function named "main" could be found WARNING(CMD407): Trying the entry point instead ERROR(CMD426): Cannot find symbol to start or entrypoint, the file or load commands may be used to set the entrypoint wait Target Message: Could not determine target state How can I solve this problem ? the workspace of the DS-5 of the project is attached.No RepliesBe the first to reply
