    --- Quote Start ---
    originally posted by hippo@Apr 9 2006, 11:20 AM
    did you install gcc32?
    check your gcc version, "gcc -v"
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14155)
    --- quote end ---
    --- Quote End ---
    yes I did that.
    $ gcc -v
    Reading specs from /usr/lib/gcc-lib/i386-redhat-linux/3.2.3/specs
    Configured with: ../configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --enable-shared --enable-threads=posix --disable-checking --with-system-zlib --enable-__cxa_atexit --enable-languages=c,c++,f77 --disable-libgcj --host=i386-redhat-linux
    Thread model: posix
    gcc version 3.2.3 20030502 (Red Hat Linux 3.2.3-55.fc5)
    --- Quote Start ---
    originally posted by mfm+apr 9 2006, 06:54 pm--><div class='quotetop'>quote (mfm @ apr 9 2006, 06:54 pm)</div>
    --- quote start ---
    <!--quotebegin-hippo@Apr 9 2006, 11:20 AM
    --- quote end ---
    --- Quote End ---
    yes I did that.
    $ gcc -v
    Thread model: posix
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14161)</div>
    [/b]
    --- Quote End ---
    Strange problem,
    please try again, reboot your Linux PC,
    cd ~/buildroot
    rm -rf toolchain_build_nios2 build_nios2
    make
    <div class='quotetop'>QUOTE </div>
    --- Quote Start ---
    cd ~/buildroot
    make
    [/b]
    --- Quote End ---
    sorry but...
    Please submit a full bug report,
    with preprocessed source if appropriate.
    See <URL:http://bugzilla.redhat.com/bugzilla/> for instructions.
    The bug is not reproducible, so it is likely a hardware or OS problem.
    make: ***  Error 1
    make: Leaving directory `/home/MFM/buildroot/toolchain_build_nios2/binutils-2.15-build/bfd&#39;
    make: ***  Error 1
    make: ***  Error 2
    make: ***  Error 2
    make: Leaving directory `/home/MFM/buildroot/toolchain_build_nios2/binutils-2.15-build&#39;
    make: ***  Error 2
    --- Quote Start ---
    --- quote end ---
    --- quote start ---
    please try again, reboot your linux pc,
    cd ~/buildroot
    make
    --- Quote End ---
    sorry but...
    make: ***  Error 1
    make: ***  Error 1
    make: ***  Error 2
    make: ***  Error 2
    make: ***  Error 2
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14164)</div>
    [/b]
    --- Quote End ---
    MFM,
    I updated my FC5 to the latest, remove old ~/buildroot, and run from line47 of build script.
    It finished without problem.
    I wonder if this is FC5 installation problem. Please reinstall FC5 or try another PC.
    As Jdhar had found the new kernel unstable. so we will back port to 2.6.11-uc0 (in ~/linux-2.6.x) . as this post is a guide for newbie mostly, we will not add more patches , (other than zImage,epcs,watchdog), to the 2.6.11-uc0 kernel here, to keep it simple and stable .
    Jdhar helped to setup a svn for the kernel and ported many new drivers, (eg, epcs,mmc,i2c) .
    Best thanks to Jdhar. You can find more updates to 2.6.11-uc0 from his site.
    http://via.dynalias.org/svn/uclinux/linux-2.6.11/trunk/ (http://via.dynalias.org/svn/uclinux/linux-2.6.11/trunk/)
    I am checking the new kernel, now 2.6.16.2 , and hope we can resolve the issue.
