15 years agounstable-nios2mmu boot error
Hi all, Here is what I try to do : I have a SOPC system with a NIOS2 with MMU. It is configured exactly as explain in : alterawiki.com/wiki/Linux_for_the_Nios_II_Processor I want to use device-tr...
15 years agoHi zben,
Did you succed to boot the kernel since you posted your message? I try to use the unstable-nios2mmu branch to use the device tree, but I have a problem. I can't find any linux-2.6/arch/nios2/boards/generic-dts/include/asm/nios.h path to modify the nios.h file.... Did you add this file or it was included in the unstable-nios2mmu branch ? With the support of device tree, did you tape only "make" in uClinuxDistr or "make path_to_device_tree.dts" in order to compile the kernel? Thank you for your help. Best regards. Pierre
