15 years agounstable-nios2mmu boot error
Hi all, Here is what I try to do : I have a SOPC system with a NIOS2 with MMU. It is configured exactly as explain in : alterawiki.com/wiki/Linux_for_the_Nios_II_Processor I want to use device-tr...
15 years agoHi,
I found the issue. In fact the device-tree generator (sopc2dts : from .sopcinfo to .dts) does not support the version 10.1 of the timer. So I manually modify the timer description in the .dts. But I forgot to add the clock-frequency value, so I got a "NULL pointer error". The timer description should be : --- Quote Start --- //Port data_master of cpu_0 timer_0: timer@0x4842000 { compatible = "altr,timer-8.0"; reg = < 0x4842000 0x20>; interrupt-parent = < &cpu_0 >; clock-frequency = <50000000>; interrupts = < 0 >; }; //end unknown (timer_0) --- Quote End --- Now I get another issue in the boot process : --- Quote Start --- fault during kernel misaligned fixup @ 0xd02157b0; addr 0x00000003; isn=0x20800017 Linux version 2.6.39-rc3-01078-gaf7b9ea-dirty (ben@debian) (gcc version 4.1.2)# 64 Fri May 13 10:56:50 CEST 2011 bootconsole [early0] enabled early_console initialized at 0xe4842020 On node 0 totalpages: 4096 free_area_init_node: node 0, pgdat d04b2814, node_mem_map d04cd800 DMA zone: 36 pages used for memmap DMA zone: 0 pages reserved DMA zone: 4060 pages, LIFO batch:0 pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 pcpu-alloc: [0] 0 Built 1 zonelists in Zone order, mobility grouping off. Total pages: 4060 Kernel command line: PID hash table entries: 64 (order: -4, 256 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 11272k/4895k RAM (2119k kernel code, 2776k data) NR_IRQS:32 late time init = d0215b28 Calibrating delay loop... 22.88 BogoMIPS (lpj=45760) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 fault during kernel misaligned fixup @ 0xd02157b0; addr 0x00000003; isn=0x20800017 Linux version 2.6.39-rc3-01078-gaf7b9ea-dirty (ben@debian) (gcc version 4.1.2)# 64 Fri May 13 10:56:50 CEST 2011 bootconsole [early0] enabled early_console initialized at 0xe4842020 On node 0 totalpages: 4096 free_area_init_node: node 0, pgdat d04b2814, node_mem_map d04cd800 DMA zone: 36 pages used for memmap DMA zone: 0 pages reserved DMA zone: 4060 pages, LIFO batch:0 pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 pcpu-alloc: [0] 0 Built 1 zonelists in Zone order, mobility grouping off. Total pages: 4060 Kernel command line: PID hash table entries: 64 (order: -4, 256 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 11272k/4895k RAM (2119k kernel code, 2776k data) NR_IRQS:32 late time init = d0215b28 Calibrating delay loop... 22.97 BogoMIPS (lpj=45952) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 NET: Registered protocol family 16 bio: create slab <bio-0> at 0 Switching to clocksource timer NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) IPv4 FIB: Using LC-trie version 0.409 TCP established hash table entries: 512 (order: 0, 4096 bytes) TCP bind hash table entries: 512 (order: -1, 2048 bytes) TCP: Hash tables configured (established 512 bind 512) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. [few second to wait here] JFFS2 version 2.2. (NAND) �© 2001-2006 Red Hat, Inc. msgmni has been set to 22 io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) [few second to wait here] ttyAL0 at MMIO 0x4842020 (irq = 2) is a Altera UART console [ttyAL0] enabled, bootconsole disabled console [ttyAL0] enabled, bootconsole disabled dm9000 Ethernet Driver, V1.31 TCP cubic registered NET: Registered protocol family 17 Oops: Exception in kernel mode, sig: 4 r1: d0c1c000 r2: 00000b0e r3: d0221000 r4: 00000000 r5: 00000000 r6: 00000000 r7: ffffff80 r8: d04d2240 r9: 00000218 r10: d04b28e4 r11: d04d2360 r12: d04d2248 r13: 00000003 r14: ffffffff r15: 00000001 ra: d021647c fp: fffffbff sp: d0c1ded4 gp: 00000000 ea: d0216484 estatus: 00000001 Kernel panic - not syncing: Attempted to kill init! --- Quote End --- I will give you feed back if I found this issue Best regards
